How many Hz?
HT = Home Theater
Meaning for home use in a home sound system, not a car.
I would also go for 30-34hz tuning, definitely not 21..
Head over to a box calculator like RE's box calc. or the12volt's or one of the other ones and play around there.
srry... im an idiot..but i no it needs 3.5ft^3.....but what bout width of the port..and is the volume of the port in with the 3.5?...srry again..nvr done ne a this be4
i think ive figured it out on res box calculator...u say in need to tune it to 32hz
i have made this way more complicated than it acually is
you will be fine tuned to 30hz //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you dont need a huge box with that sub
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
mccoy
mccoy
pikeville, ky
Slammed
    May 18, 2024
    May 16, 2024
