How many watts from an old Rockford Fosgate 40x2?
I'm going out on a limb here and going to say
40 watts per channel
Total of 2 channels
Proper voltage, I'd say around 55-60 per channel as they were slightly underrated.
Ok, and how about being 2 ohm stable when bridged mono?
It seems like some of the old school amps (in general, not RF) were under rated... like a 22x2 amp doing a couple hundred watts bridged.
According to the owners manual it Dynamic power(14.4volts) is 175watts mono @ 4 ohms
80 watts x 2 @ 2 ohms,60 x 2 @ 4 ohms
Power at 12.6 volts is 20 x 2 @ 4 ohms
40 x 2 @ 2 ohms
80 x 1 @ 4 ohms
Yes,Rockford were great amps then.They could achieve great thing so long as you didnt starve them of power/voltage...here is a link to the owners manual...its a pdf file
http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/fattach_get.php?p_sid=ZRxvLLVi&p_tbl=9&p_id=380&p_created=1084295973
According to the owners manual it Dynamic power(14.4volts) is 175watts mono @ 4 ohms80 watts x 2 @ 2 ohms,60 x 2 @ 4 ohms
40 x 2 @ 2 ohms
80 x 1 @ 4 ohms
this is what you got, there was punch 40, 40i, 40ix, 40x2. they just didnt change the amps design as frequently as they do today.
i wish all amps were rated like that today....
i agree, im from the os and it sickens me what has happened to amplifier ratings. wiped out a few competition classes along the way. no more 100w, 250w, 500w classes. that *****, the 100w class was my personal favorite. you had to be very creative to do well in that class.
Hell yea!And if you had a 1000 watts you were pro...now a days 1000 watts just aint the same.It would be novice to say the least.We would need 3000watts today to even come close to back then
Hey all, how many watts can I get out of an old RF 40x2 amp. And is it 2 ohm stable when bridged mono?
Technically NO...But I ran mine at 2ohm bridged and it screamed.It worked but I was dumb then.I figured if it couldnt handle it..then the fuse would blow.Ive had a couple that held at and 2 ohm bridged but did have 1...a punch 200 dsm that only lasted about 3 months at 2 ohm then finally gave out //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif...I personally wouldnt try it now on such a lovely amp
Thanks everyone for the info on this old Rockford, and thanks spnkysprky for the pdf file. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
coolest user
Majician
coolest user
In the Middle
Zuzu$1967
    May 24, 2024
    May 23, 2024
