how many watts would this be?
  • 2
SuckMikeHawk23
#1 Laker Hater
i am running 2 fosgate he2's and am going to upgrade my amp to a fosgate 500.2, my question is, if i hook my subs in a paralell-series mode into the bridged channel of the amp, will i be getting 500 total watts? or 500 watts each speaker? or if they are both wrong, how many watts will i be pushing total and/or each speaker? thanks
If you end up with a 4ohm load to the amp. You will have 500w total. Actually a little more because most fosgate amps are under rated. Each sub would get 250w.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
SuckMikeHawk23
#1 Laker Hater
SuckMikeHawk23
626 California
ramos
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
