How much power will an AQ-1200D actually produce?
  • 4
Either one would do you fine. The difference in wattage would be negligible. I decided to take a SK-1500 over an AQ1200, actually
Alright. I haven't heard of the amp you mentioned. I'm pretty set on the AQ, and was curious as to how much power it actually puts out. Some have said it puts out rated, some have said it's been "benched" and actually put out ~1500w @ 1 ohm.
DJ doesn't play the underrating game like some other companies, amp does 1200w @ 1ohm. I've owned a few of them, very solid little amps....
between 1200w and 1500w will be negliable to the ear unless you are in an all around burp class where every watt can make a difference. Just pick one which you find more asthetically pleasing/fit your budget and go with that one.
Specs https://www.skaraudio.com/products/vxf-15-inch-car-subwoofer
I would suggest 80 ah of yinglong lithium and a H/O alternator. I'm running 40 ah with a 320 alternator on a 3.5K and it isn't enough.
31
5K
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
akillj
akillj
CA
Julian
Decebal
    Jun 10, 2024
