How to figure displacement of a 2x4
Multiply the length in inches by 8. This will give you the volume of the board in cubic inches.
Do you need to know the conversion factor between cubic inches and cubic feet?
lol, really i think im about to just use 1.5 inch dowel rods, my math is a bit rusty....
hm... never mind i think i have it? 20in * 8 = 160 cubic inches = .0.092
a 2x4 generaly measures 1.5" by 5.25 or 5.5 depending on the store you go to.
actually measure what you have and plug it in to the woofer box wizzard at rockford fosgate site
would state that a piece of 2x4 measuring 1.5" by 5.5" by 12" long will displace .06 cubic feet
and that same piece of 2x4 measuring 24" long will displace .11 cubic feet
a 2x4 generaly measures 1.5" by 5.25 or 5.5 depending on the store you go to.actually measure what you have and plug it in to the woofer box wizzard at rockford fosgate site
ok so im getting confused now with all this. what i need to figure is a 2x4 @ 20in long & another 2x4 & 18.5in long
A 2x6 measures 5.5. A 2x4 measures 3.5 x 1.5.....
Length x width x height = displacement since this is in inches divide the sum by 1728 to get cubic feet of diaplacement. (12x12x12= 1728 cubic inches in one cubic foot.
Here simplest form....
20 inches long = .061
18.5 inches long = .056
This is what 2x4 ' s are in those lengths. Sorry you got so many answers for a simple question
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
6
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
So, to follow up, I got everything working properly again. If you refer to the photos I sent of the amp internals, you can see there is that white...
14
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
bgowdy
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
