how to go 14 volt 2008 f150?
  • 5
Well as the title implies I am trying to figure out if I can controll my alternator to run 14 volt system. I have a 2008 f150 4.6. It is computer controlled. Does anyone know how to get around this? Will an external regulator work on it? Do I need to change to a non computer controlled alternator? Are there parts that can be changed in the stock alternator to allow an external regulator to work? Any help would be appreciated.
no they dont.
all cars/truck are 12 volt systems. when running they are around 14.4volts.
and no you cant change your system. and you dont need to change it.
do you know if the electronics system will accept a 14v system, will they take 16.5volts? if so it is easy, otherwise you can get a adjustable voltage alt, use an isolator run one side to the 14v batts for the system, and the other side through a voltage reducer (powermaster or XS 993) it will reduce the voltage by ~2.5volts to run your vehicle.
Budget is ~$1k minimum
the vehichle electronics should be ok with the extra juice, what I cant figure out is a way around the fact that the computer controls the voltage output of the alternator so I don't know if I can just hook up an ext. reg.
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
And it works great with android phones, you can connect, and what can you say about android radio tape recorders are now leaders in functionality...
ie just used a new adapter because adapters ignition wiring wouldn't keep constant, works fine now and stopped sending sensors off, never had the...
donkyhooker
donkyhooker
Chesapeake,VA.
LosIsATool
