how to help electrical system
  • 4
I think about the only time a cap really helps with light dimming is when you wire one to the lights themselves //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What gauge wiring are you using and times 2 on the big 3.
It's basically upgrading your under hood grounds and battery to alternator wire, Cheapest electrical upgrade you can do.
what car is it? maybe your gains are set too high causing the amps to clip (pull irregular voltage) thus causing excessive stress on your electrical system. how did you set your gains? with a multimeter I hope
link to more info?
that sounds like it could be the problem. i did not install my system my brother did buy im getting it redone with a dmm
190
hdj20
F*CK SONY
hdj20
wisconsin
alvitae
