How to hook up mp3 player to Eclipse AVN52D
  • 2
well i know for some decks, there's an aux adapter, it attaches to the back of it on i think RCA cables in one end, because there's 3 pairs of open slots behind the headunit, and the other end should have that adapter should have aux input, . and you just get an adapter for that headunit. i don't know if this applies to all, but you can get an adapter that way. i know some pioneer decks do this, maybe see and eclipse does as well
138
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Pistonsfan70
Pistonsfan70
Detroit Area, MI
dafobbishon3
    Jun 1, 2024
    May 31, 2024
