Hu Shuts Off .!!!!!!!
  • 2
63novawagon
CA
I have a Panasonic DFX883U cd/Mp3 player. After listing to a cd for 10mins the HeadUnit will shut off Automaticly. Does anyone know why? Its not because i turn the volume up high. The Ground is great so i dont know why this happens to me? Does this means it's Fried or Shorten?? LMK
any ideas
have you checked your battery and alternator, sometimes when the voltage input to your hu gets low, it will automaticaly shut off, or if it gets too high
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
824
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
709
6
144
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
63novawagon
63novawagon
CA
Dragonknell
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
