I could use some help...
  • 2
MRBlackburn
CarAudio.com Newbie
Canada
Alright, I have a Subaru Impreza 2006 with a stock stereo ... It has no AUX and I've been tired of using an FM transmitter because they're noisy so I bought a cheap Kenwood KDC-MP338 stereo with AUX input. The wiring harness head did not fit (obviously) so I cut wires and started taping... (I know most of you are going to talk to me about soldering or caps... I understand I hacked it in, but honestly its just for AUX input so I don't care much).
Anyways, I was having a hell of a time getting the wires right. I used two diagrams (I'll post the websites at the bottom) to match the wiring but I could not get any power to the display and I also lost dash lights in the process. At one point, some wires crossed and the stereo/dash lit up... I ended up connecting the Subaru +12Volt memory wire, to the Subaru +12 Volt Accessory wire, and the Subaru Illumination+ Wire and then connecting that to the Kenwood Ignition wire and battery wire... I know this is a mess, but it worked...
Everything works fine except one thing, my car dash (clock, KM tracker, and stereo) have no memory... Any suggestions? I know I did a pretty rusty job but I was getting annoyed trying.
These are the diagrams I used:
Kenwood - https://www.manualslib.com/manual/777461/Kenwood-Kdc-Mp338.html?page=19
Subaru - https://pinoutguide.com/Car-Stereo-Subaru-Suzuki/subaru_impreza_wrx_pinout.shtml
There is a wire that has a constant 12 volts, even with the key off. That should be hooked to the stereos memory wire. You need a cheap volt meter. much easier than studying a manual and hoping it’s right.
I think I found the issue, the fuse for the memory was blown. When I changed it, the stereo stays on when the car is off, I've got to go a readjust the wires and it'll be fine... Hopefully. Good call about the volt meter. I'll see if I have one.
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
80
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
128
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
237
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
705
MRBlackburn
CarAudio.com Newbie
MRBlackburn
Canada
MRBlackburn
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
