SOLD I need an amp
first thing i see is you need to have your mind set on 1 or 2 first so you know what ohm load amp to be looking for... 1 sx=1ohm or 4 ohm stable at max rated output or 2 sx's= 2ohm mono amp or 2 amps strapped that handle the 2ohm load when strapped...
853
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Hyybrid89crx_si
I'm Special
Hyybrid89crx_si
somewhere
Hyybrid89crx_si
    Jun 1, 2024
    May 31, 2024
