I need help with my amp please.
  • 2
Well, unfortunatly no.
your amp might put out a good deal of power to the sub because of the fact that channels a and b are bridged, wich will cause the a and b channels to run at 2ohms each to make the total 4 ohm mono load, and its only amplifying low frequencys which make the greatest power demands on an amp.
But channels d and e are running stereo at 4ohms each and amplifying the high frequencys, which don't need alot of power to be loud.
Now im assuming your running one of those 800 watt four channel amps right?, If thats the case it would probably be safe to assume that the bridged channel would put out 150 to 200watts rms and the stereo channels would put out about 50 to 75 watts rms each.
11
855
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Kearn
Kearn
Oklahoma City, OK
stones
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
