I need some advice and recommendations
  • 2
snb778
blaugh!!!!
Hey guys,
I was originally going to run my Treo Engineering SSX 18", but decided I don't want to go through upgrading the alternator.
Where is the most you recommend running off the stock ALT with an upgraded battery? Can I get away with 2KW?
I'm looking to run 2x15's now, something around 750RMS. I'm not to familiar with this power range, what do you guys recommend? Something around $150 each preferably
Needs to fit in a 2010 Maxima​
thanks
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
383
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
505
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
839
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
THATpurpleKUSH
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
