I Need Your Expertise Guys!
  • 3
Dentaldude45
SLC
I am trying to install a pioneer Deh-245 am-fm CD in dash stereo into my wife's 87 Jeep Cherokee. When bought it came with an after market Sony CD stereo with it's special quick connect wiring harness. I have tried to cross splice but the colors don't match up after about six wires. Where do I go from here to match up with the cherokee wiring harness. Are quick connect harness' out there to match up to my Pioneer to the 87 cherokee? Or, is there a cross reference wiring guide to use with the harness from the sony to cherokee where I can splice in? Any help would be appericated!!
Mike:crazy:
Often times the factory harness noes not have everything that your deck has so seperate wiring is sometimes needed..If you arent running an amp then dont worry about the remote turn on or the power antenna leads..If you are gonna run an amp you will need to run those wires..Either way the factory harness should have constand and accessory power and you can use the ground provided but I would ground it elsewhere due to the size of the factory one.. All speaker wires should match up..On the harness adapter the wires should be labeled you just have to bust out the magnifying glass to read sometimes.
Mike
as it seems, this is the general color wiring for most cars..
battery/memory orange black
ign yello
fr+ light green
fr- dark green
fl+ tan
fl- grey
rr+ dark blue
rr- l blu
rl+ brown
rl- yello
park lite grey and brown--1 may b a dimmer circuit, test carefully or do not use
earth black
there may be a green white wire-- do not use or ground---insulate it , cos i think it cocks up the speedo.
i got this a while back, someone else posted it and it was true for my car, and others i have worked on...hope it helps:)
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
526
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
384
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
422
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
629
Dentaldude45
Dentaldude45
SLC
McCraperson
