MiniflexAlex 10+ year member
Hello,
I did install a rear view camera last night in my VW Passat.
Part of the job was to run the camera wire incl the plug thru the rubber/plastic tubing from the trunk lid into the cabin.
Well, this tubing is very small in diameter and there is already a pretty big wire in there....so I tried to cramp the camera wire thru...unfortunately I broke 2 wires during this process and I still did not get it thru.....
So I thought, it's broke anyways, I just cut of the plug (which is the reason why it wont fit thru the tube), pull it thru the tube and solder it back together once the cable is in place.
To my surprise 'after cutting the cable' there are only two individual wires (1x yellow, 1x red) and a bunch of strands.....the end of the plug however, has 5 individual wires coming out of the cable (2x red, 1x yellow, 1x brown, 1x black)//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif.
So how is that suppose to work, how should I make up the second red cable, the brown cable an the black cable....The plug is a 3pin plug
I really trying to salvage the cable as I dont want to spend another $$$ on this system and I also have my doubts that I even get the cable without buying another camera.
BTW. It is a Pioneer camera, ND-BC5.
I'm extremely desperate right now, so your help is much appreciated.
Alex
Here are pictures of the screw up.
Alex
