Identifying old mtx sub
I paid 30 .it sounds good on 300 watt amp.
I'm not using these as a main but just something to hit lower notes that my 4x10in subs cant
Mixing sub sizes, unless you really really know what you are doing, is usually a bad idea. And almost always the worst way to fix a problem with frequency response. To do it properly it would require significant processing, a lot of testing, and getting a bit lucky. Four 10's is plenty of cone area to get solid output down to 20hz, unless the enclosure design doesn't allow them to, or enclosure location/firing direction is causing problems.. Check your box alignment and position before just tossing a 15 in the mix too. Id suggest either altering the four 10" setup you have now, or replace it entirely with a different setup that has the frequency response you are looking for.
That is TOTALLY it! Thanks all! I couldn't find it for the life of me.
If you have the patience, you can definitely rebuild it. Hardest part would be to find the coil that best fits it. It may not be a common size...
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Zachary Rafferty
Zachary Rafferty
audioholic
pfft
    May 1, 2024
pfft
    May 1, 2024
