Impossible to figure out speaker polarity?
  • 4
Hello everyone,
I am very confused on the polarity of the following tweeters:
https://rb.gy/abe5rl
I've had them for a while but I'm just getting around to installing them. Can anyone see what the polarity is supposed to be?
Both wires have the same spade connector, neither sides have a dot / plus / minus /any indication. I tried connecting a depleted 1.5V battery (the small one to not overheat the driver and I only held it for a second or two, it was also down to 1.1V), but since it's a tweeter I couldnt see if it was moving in or out...
Any help appreciated!
BND
Mine iirc had a red spot and a black spot on each side on the bottom of the tweeter.
I bought mine back in 2018 but never got to install them till now... Maybe it got smudged off.
Anyway, looking through the pics on Ebay I found one pic where there is a red dot but the pic is from the side so it's hard to tell which side this is.
But I noticed a small "bump" in the picture (circled in red and arrow pointing towards it) which makes me thing that's the Alpine speaker, so if that's the case it may help me orient it this way.
28934
I also emailed the seller, so hopefully I get some kind of answer back. Thanks for the help!
BND
I feel like it may be the alternator. The physical unit has the exact same whine. It's pretty new, but I'm also not sure if this is normal or not...
8
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
6
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
BroncosNeverDie
Washington
BroncosNeverDie
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
