In need of enclosure design, preferably free
  • 4
I need driver T/S parameters to punch in software.
you know this ****:
SP418
DUAL 1 | DUAL 2
Fs: 24.7 Hz | 24.9 Hz
Re: 0.65 Ohms/coil | 1.27 Ohms/coil
Qms: 7.45 | 7.38
Qes: .60 | .59
Qts: .55 | .55
Mms: 555g | 544g
Cms: 0.74mm/N | 0.74mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 153.7 l | 153.7 l
Spl: 87.8dB 1W/1m | 87.9dB 1W/1m
Bl: 13.7 N/A | 19.1 N/A
Xmax: 33mm | 33mm
Rms: 3000W | 3000W
Sealed box: 4-6 cuft | 4-6 cuft
Ported box: 6-8cuft | 6-8cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth:11.750” | 11.750”
Displacement: 0.26cuft | 0.26cuft
SP418
DUAL 1 | DUAL 2
Qms: 7.45 | 7.38
Qes: .60 | .59
Qts: .55 | .55
Mms: 555g | 544g
Xmax: 33mm | 33mm
Rms: 3000W | 3000W
I'm getting the dual 2
Hey man, I can really guide you if want. I've had several buddies that have crown vics, one of them had a BTL 18 in the trunk. Hit me up tonight if you can.
I've had the great opportunity to build a few of your designs. Thanks man. This guy can help you op.
Hey man I'd appreciate any help!! I've built a couple generic boxes for buddies but nothing crazy and want this system to sound awesome as it will be my daily with a few comps setup! I've been all over the Internet and can barely find anything worth my time cause I don't know a whole lot yet, this sp4 will be my second system...
What are you asking? Are you needing enclosure help for a subwoofer upgrade?
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
7
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
484
Dquimby417
Dquimby417
Rochester, MN
Dquimby417
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
