In need of replacement woofer for Pioneer Rev Component Set
  • 4
qtipextra
The Original
Wow, it's been a long time since I have been on this site.
OK, so I have a pair of Pioneer TS-C160R Rev components. However, one of the mid-range woofers has died on me. Bad news is, they are old and I cannot find a replacement for just the woofer.
I don't want to have to replace the entire crossover set, just the woofer. I've come to the conclusion that that is not going to be a possibility. So I need some help finding some new mid-range woofers that I can just swap in place of the old ones, and use the same crossovers and tweeters.
4 Ohm, 60 W RMS.
Any suggestions?
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
487
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
374
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
412
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
612
qtipextra
The Original
qtipextra
Idaho Falls, Idaho
KyleBechtold
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
