in need of serious help with audio terms
PV Audio
The Vision of Sound
20,912
Indy
ok people, i need to know what the differences between the following are
frequency
octave
pitch
key
wtf are the diffs? i play the piano, and know what an octave is and what a key is (sharp/flat). but how does an octave relate to frequency? the higher the octave, the higher the frequency, and the lower the octave (a1 on the piano is the lowest) the lower the frequency. but when you change the pitch of a note, it either gets higher or lower...could someone enlighten me? i'm lost.
yes there is. after 400 posts your not supposed to be a n00b anymore. he has over 3k. He should know about the sticky.
you can still be a n00b after 9k posts, everyone is learning man. yes i looked in the sticky, but it didn't give me what i needed.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
137
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
192
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
144
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
501
PV Audio
The Vision of Sound
PV Audio
Indy
PV Audio
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
