Inifinity Amp wont turn on without jumping the 12V to remote using a small wire
  • 3
Dean
Bangin' S10
Hey guys. Just installed polk db components in my silverado doors, and polk 4x6s in rear. everything is all wired up. But the amp will not turn on. If i take a peice of wire, and connect the 12v and remote terminals, the amp turns on but goes on and off, from clip, to protect mode to on/off. and the speaker pops. not sure whats going on. It is a 4 channel infinity reference series amp
it could be a bad ground... check the ground wire first. and for the remote wire situation. i just ran two wires. one from the 12v n one from the remote to the front of my car and just put a switch on it, so the amp doesnt stay on all the time
Thanks for that! The ground is really ****** . Bout to tackle it in the morning finally got some time.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
114
6
354
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
660
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
477
Dean
Bangin' S10
Dean
Western MA
robert420
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
