Installing CT Sounds Meso 3 way and the AMP is to powerful
dalefavero20
Hello,
I am currently designing my system, and I intend to use a Audio Control DM 810 to tune and crossover my system. To that end I have questions about installing the tweeters and midrange speakers on amps that are rated too big. The smallest amps I am seeing on CT sounds are 60 watts / channel. The tweeters are rated for 50 watts/pair RMS.
Is there a reliable way to amplify them without overpowering them?
Do i adjust the gain down on that channel?
How do I relaibly measure to make sure I have it set right? Multimeter and measure the output voltage 50 Watts = V X 4 ohms so Volts = 6.25 at 25 watts?
Thanks for your time
Dale
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
for my amp ground I have it to the paneling in my trunk, secured with a bolt and a nut. I sanded as much as I could, and I used a grind wheel on...
72
6K
dalefavero20
dalefavero20
Washington
RedRyder18
    May 11, 2024
RedRyder18
    May 11, 2024
