Installing Double Din in 2004 Harmon Kardon Mercedes
  • 3
The_Grimy_One
Phoenix, AZ
I am looking for some insight on how to run an aftermarket headunit in my Mercedes.
I do not need anything fancy. I just cannot stand the stock headunit.
I guess I am most interested in the bare minimum I need to make this happen, and has anyone done it?
I do not care about having FM/AM. I do not need to retain navigation, or a CD changer.
I probably won't even bother setting up the steering wheel controls, but maybe I will if it isn't too hard to setup.
I know everything revolved around the MOST fiber optic interface... But that is about as far as I have gotten.
Thanks for your input.
I'm replacing everything in my 2007 Mercedes CLK350. From my understanding, if you replace the head unit you must replace the factory amp also.
That is what I used to think as well. But I have been doing some research, and the MOST fiber optic amp interface will allow your aftermarket headunit to send a signal to the stock amp. At least for the Harmon Kardon setup. What I am a bit confused about is that you need to either terminate the fiber optics with a loop, since the deck and the CD changer use fiber optic. Or maybe you can leave them plugged in... I am not 100% sure yet. I will send you some of the info I have found.
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
129
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
The_Grimy_One
The_Grimy_One
Phoenix, AZ
ciaonzo
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
