is bracing and 45 in corners really worth the money?
Assuming all boxes were created equal 45's increase the strength of a joint a huge amount.
I broke apart some old boxes I built today and the ones with 45's were way stronger.
Andrew
Andrew
But the boxes without 45's didn't come apart from normal use correct? If so then 45's weren't necessary...
---------- Post added at 03:20 AM ---------- Previous post was at 03:19 AM ----------
OP I highly doubt any prefab out there has the right amount of port area for a DD sub...
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
Historically better economy under Democrats.... ********. CPI:
176
Thanks a lot. iPhone charging. Wow. No cigarette lighters now.
35
6K
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
Radiospank
Radiospank
los angeles
disturbed471985
    May 18, 2024
    May 18, 2024
