Is more louder?
  • 4
Surely your joking right? Adding more subs doesn't increase the "loudness," you need to also add more power (amplifiers), batteries, etc.. Understand the basics of car audio by doing a little research before asking questions that will make you look bad.
You can have 1 15" Sub with an amplifier feeding it (as an example) 2k watts (if the sub can handle it), in a finely crafted ported box made to the specs of the sub. This 1 sub/amp/box combo will be louder than the simple addition of more "bandpass" (I don't know what you mean exactly when you're stating this) subs.
Doing the setup right the first time will save a lot of time and money in the future.
you dont want to mix sub sizes period man, it'll make you go negative on the sQL meter. This is your 2nd thread about this man. People gave you advice whether you take it or not is up to you but dont clump with useless threads. Instead of just adding more, why dont you get better quality ones instead, your tobey speakers subs are in a good box but it doesnt mean they are the best subwoofers to get loud with for the money.
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
7
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
494
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
671
speedyjuarez
Premium Member
Premium Member
speedyjuarez
Live in Hobbs, NM. From Ft Worth, TX
DoesDad
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
