Is the port included or excluded from the box volume?
  • 3
Cunuck
Hello, exactly what the title says //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. I am wondering if the port area is included or excluded when you are figuring your box volume in a slot ported box. Thanks. Also when determining the port volume would you just do WxHxD (depth of whole box) or WxHxL (length of port). Thanks.
Yes.. Unless you're talking about port displacement..? That's when you'd need WxHxL...
Maybe he is trying to do all the calculations by hand..? I'm not sure lol. I just like the convenience of plugging everything into Torres and it doing all the math for me.
I guess it ISN'T safe to assume that everyone uses a decent calculator, even though they're free and recommended in virtually every box building guide..
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
784
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
963
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
940
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Cunuck
Cunuck
St. Petersburg, FL
Cunuck
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
