Jl 1000/1 keeps blowing up subs
Llt1980
34
Iowa
I have a JL 1000/1 its about 11 years old I had a pair of 12 inch jl 0w3s on it when I got it they worked fine then I put a pair of power acoustic 15s rated at 1000 watts for the pair and blew them up in a few months a pair of 10 inch kicker cvr rated at 800 watts for the pair they lasted a half an hour and now 2 jls 15 w3 rated at 1000 for the pair and they only lasted a month and this time I had a JL dealer install them is it a problem with the amp?
If the shop is reputable, and it blew the subs on their settings the subs are on them unless they can prove the amp is bad. You can have them ship the amp back to jl and they will put a new board in the amp eliminating the amp as the potential problem
My question is where is the gain knob set when this happens and where is the bass boost?
Are you using bass boost on the radio?
The same jl shop put it on the first set of 12s it was on and I haven't even looked at the gain since I don't think I have any bass boost on the deck its an alpine cde-172bt it has been in 4 different cars a 91 firebird with the jl 12s 0 gauge wire with a cap the power acoustic 15s in a 99 dodge ram 0 gauge cap a car 10s 06 mustang 0 gauge with a cap and JL 15s in a 16 Hyundai accent 4 gauge with no cap
if a JL Audio certified dealer done the work then it is certainly backed up but not sure how the subwoofers would blow up as one have to drive the subwoofers into distortion for a few minute for the effect to take place!!!
JL Audio gear is pretty tough and well known brand so there is no question about their products but if you keep blowing subwoofers then something is the cause.
If possible for you, try another amp (from a mate as well as a single subwoofer and use it for a week to see if any issues arise.
You may need to take the JL Audio amp out and get it bench tested from a knowledgeable person before you take it to a repair shop.  This action is to get a second opinion on the amp and to rectify the amp is definitely the cause of the subwoofer blowing up.
Let us know how you go mate, as some components can fail over time and with amps, its hard to determine unless it is thoroughly tested by a reputable person who knows what they are doing.
Good luck and let us know how you go, mate! :veryhapp:
Using a meter check the DC voltage from power ground to the + and - sides of the speaker terminals. You should measure about 57VDC on BOTH sides of the speaker terminals. Also measure across the speaker terminals. You should measure less than 1 VDC. If you measure more than that then it's not balanced and you have a DC offset problem with the amp. If you measure several volts or more that DC voltage will just heat up and slowly cook  your voice coils in your subs and permanently damage them.
Winkychevelle is on point. After blowing a few sets of subs, I wouldn't continue trying other brands and buying more subs until I look into the problem/issue. My guess is the same thing winky has already stated. That said, get back to us for proper gain setting on the amp or search for a tutorials online or youtube. It'll save your 5th set of subs from being blown.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
777
Llt1980
Llt1980
Iowa
Boomin_tahoe
    May 16, 2024
    May 16, 2024
