JL 1000.1 Low Voltage Indicator / Strange circumstances
JohnnyZ
Hi Guys,
Everything has been running superb until a few nights ago. I hop into the car, hear my subs, turn the volume up to 12, sub cuts out. I go to the trunk and see the low voltage indicator light on. I turn the car off, rinse and repeat same problem. Sometimes I can literally blast the sub too for a short while and it will not cut out. This leads me to believe it's an electrical problem not the amp. The sub has been pounding for the month I have it with no issues whatsoever. The battery is only a few months old. I have a cap in the mail that I was going to try for shits and giggles but I am lost in to what way I should approach this. I haven't used the volt meter yet to check anything.
My questions:
What is the likely hood that the amp actually gave out?
What approach should I take with a volt meter?
Things I have done:
Checked / cleaned off all grounds (minus the alternator)
Remount power cables
My current setup:
JL 1000.1
JL 13.5 W7 / Huge Ported Box
Eclipse 3 Ways
RF T600.4 (80 (4 x 20) AMP Fuses)
Pioneer Indash
4 Gauge Wiring wherever applicable
100AMP Fuse before battery
10 Farad Cap not installed yet
Thanks for the help in advance!
Whats the best way to test the front battery. Dump a load onto it and make sure the voltages dont drop below a certain level, or just if it is in the healthy level? If so, what would that level be if the car was off and or on.
I have a 100 amp fuse before it, it seems to be working fine.
No, auto zone or any auto parts store will test them free. Ide get my alt checked too
I guess it's simple logic but if your amplifier is telling you it's protecting due to low voltage, why not check the voltage going in to it? That seems to be the most logical thing to me. Then if the voltage really is something less than 13.8v in the back with the car on, you can then test the alternator etc. A bad battery would have problems starting the car. It would have nothing at all to do with low voltage when the car is on.
Alright so here are some results:
Car on:
Battery Reads: 14.2
Sub Amp: 14.2
Speaker Amp: 14.2
System on volume 8
Battery Reads: 14.1
Sub Amp: 14.1
Speaker Amp: 14.1
> volume 8
Battery Reads: 14.1
Sub Amp: 4.2
Speaker Amp: 14.1
As soon as I start drawing more power the sub amp drops to 4.2 v then gradually builds backup. I didn't have time to swap the power/ground from the 4 channel amp to the mono block, but without doing that does this sound like a bad ground for the monoblock?
Car on:
Battery Reads: 14.2
Sub Amp: 14.2
Speaker Amp: 14.2
System on volume 8
Battery Reads: 14.1
Sub Amp: 14.1
Speaker Amp: 14.1
> volume 8
Battery Reads: 14.1
Sub Amp: 4.2
Speaker Amp: 14.1
It sounds like a terrible ground. Something is way wrong.
well the 1000/1 do draw some current and with you running 2 amps id go higher than 4 ga, def do big 3 if you havent, and return that capacitor and do a Battcap or just another battery. And check your fuse itself under the hood as mentioned. Sometimes they go bad depending on what kind you have. One of my ANLs use to do the same thing... id turn it up and it would cut out. replaced the fuse and was good to go.
Your a ninja
It could be the fuse. It can't be the 4 awg. That amp only has 4 gauge inputs (not that it really matters at all). He is dropping due to resistance in the line. That's USUALLY a bad ground, but a bad fuse or bad connection can easily cause this. The 4 gauge not being enough would not drop so low in this scenario.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
803
JohnnyZ
JohnnyZ
Foxboro, MA
JohnnyZ
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
