JL 1000/1.. willl it do 1000?
Here is the ultimate shock.... the JL Audio 1000/1 will do..... get this... AT LEAST 1,000 watts RMS between 1.5 and 4 ohms.
= under rated.//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
796
nickolas_j_t
I approve this message
nickolas_j_t
Midwest
smgreen20
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
