JL Audio 12" W6 W6v2-D4 USED
DaJuice
JL Audio 12" W6 W6v2-D4 Dual 4 ohm.
Used for almost a year. I have it hooked up in my BMW to JL 500/1. The stock Harmon Kardon is junk, so I added the JL to clean up some of the bass. The sub has never been abused. I don't need people hear me coming from blocks away. Never distorted or over powered. Box is Not included.
Some specs from JL website.
12" Subwoofer
RMS Power : 400W
Dual 4 Ohms 2.75" diameter
4-layer voice coils
Sensitivity : 85.9 dB
Customizable Trim Ring
W-Cone : Delivers Stiffness with Minimal Mass
Floating Cone Attach Method : Better Excursion / Dynamic Voice Coil Alignment
Plateau reinforced Spider Attachment
Pole & Cone Venting
Forced Air Cooled Aluminum Alloy Frame
Highly Optimized Motor Systems
Large Progressive Roll Spiders
Engineered Lead Wires & Connectors
Mounting Depth : 7.6"
Approximate Weight : 26.1 LBS
$200
$30 I will only ship in the U.S. excluding AK and HI
Wrong user name^
Little scratch top of the the sub
Little blemish top corner
In the video It was being played a little louder then I usually listen too it.
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
188
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
DaJuice
DaJuice
Longmont, Colorado
DaJuice
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
