SOLD JL Audio e1200 Mono amp
  • 4
N2Audio4life
I have a JL Audio 200 watt rms mono amp only used for about 3 months i would rate this amp 9/10 on looks and 10/10 on performance. Very powerful amp for its size. Asking $100 shipped
Class AB Monoblock Full Range Amplifier
Patented Absolute Symmetry dual N-Channel MOSFET output design
Pass-through RCA outputs
State-variable, 12dB/Oct Butterworth crossover with continously variable cutoff frequency selection from 50 - 200Hz.
Configurable as High or Low pass Filter
High level inputs
CEA-2006 Compliant
RMS Power Rating:
200 watts x 1 chan. at 2 Ohms
120 watts x 1 chan. at 4 Ohms
Frequency Response: 10Hz - 25kHz
Damping Factor: >200 @ 4 Ohms / 50Hz
Slew Rate: +- 22V/us
Input Range: 200mV - 8V RMS
Bass Boost: 0 - 6dB (0 - 18dB with Bass remote - Not Included)
Dimensions: 9.8" L x 9.25" W x 2.36" H
I might be extremely interested in this amp. I have my uncle mailing me down a JL sub im pretty sure it's 200rms 4 ohm. but im not 100% sure what model sub it is so i will have to make sure when it get here
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
200
N2Audio4life
N2Audio4life
harriman, TN
N2Audio4life
    Jun 1, 2024
    May 31, 2024
