JVC KD-X330BTS Bluetooth malfunction
  • 2
Maraizeq
CarAudio.com Newbie
Jordan
I just upgraded my JVC "KD-X330BTS" unit firmware from ver.0106 to ver.0123, the process completed and the unit rebooted successfully.
Unfortunately, after that Bluetooth feature didn't work, either in "source" button or by "settings", all the time keep giving me "PLEASE WAIT" then "H/W ERROR" on the screen, other features work fine, although the unit became very slow in tuning.
try to reset the unit and repeat the whole process again and again, but nothing changes.
You're absolutely right.
Manual said reset button should be pressed twice within 5 seconds to rollback to factory reset, i did it so many times, nothing happend.
So the issue persists? If yes, you may have to do the unpleasant task of opening the radio to disconnect the battery. Battery may be soldered on, which will make it difficult.
Maybe when opened you will have an easier go at the reset button.
Google do it translate what ever i do
4
314
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Maraizeq
CarAudio.com Newbie
Maraizeq
Jordan
1aespinoza
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
