JY Power HP40 Discontinued
  • 3
metalheadjoe
Unapologetic prick
2,067
937
ND
JY Power's website lists their HP40 battery as discontinued (less than a month after the warranty expired on their first run), and they no longer list any batteries as products. What the fuck?
Anyone else own an Hp40? I haven't opened mine's case; are they rebuildable either with LiFePO4 or LTO cells? My HP40 was fantastic initially, but this winter it has really pissed off my ECU to a point where I pulled the battery yesterday. It still holds ~13.4v resting, so I don't think it's toast. I'm annoyed that JY hyped this battery so much and charged so much for it, and now they've abandoned it.
End rant.
Well that *****. I got a terrible vibe from all the car audio branded battery companies when I was initially investigating lithium. Glad I passed there. What's worse is that 1/3 of your budget in building one yourself is going to be just the copper and hardware or whatever so if the cells themselves failed you could at least rebuild for less money.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
593
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
755
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
573
metalheadjoe
Unapologetic prick
metalheadjoe
ND
hispls
Decebal
    Jun 10, 2024
