Kicker 11DX4004
  • 4
okay thanks yeah I figured something was up when i couldn't find much on it, in that case whats a good 4 channel amp that won't give me alternator noise problems?
Alt noise comes from poor grounds, poor RCA's, generally. Unless the amp is internally damaged or your feeding it a bad signal from the HU not being properly grounded, some of the pioneer HU had a problem with the rca outputs losing there ground and it created a signal interference thus getting the altered signal to the aml and it just amplifies the sound.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
812
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Eddster77
Eddster77
Asheville
basswiigee
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
