Kicker 1200.1 or SIA 1250?
Which is the overall better amp for a SA v.2 D4 10' subwoofer? Which one would make the sub have better sound quality especially on the lows?
The kicker as long as it's not the base model probably will sound better but I doubt you could even tell th difference. The sia amp is a good amp all the same so I would go off of price and brand preference
497
986
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
bryanarriaga67
bryanarriaga67
Texas
audiobaun
DEW123
    May 7, 2024
DEW123
    May 7, 2024
