Kicker 6.5" CVT vs. ED E3.6
FAM4LIFE
SHILOH BOY
I currently have two of the Kicker 6.5 CVTs in a .6 cuft sealed box being powered by a Kicker zx 300.1. Although I didn't expect any real low end out of 6.5" subwoofers, its almost like the factory speakers in my rear doors get lower off of my h/u. Now the higher sub notes are loud but low end is missing all together.
I noticed the E3.6s from ED have a lower Fs than the Kickers (28hz vs. 53hz). Will I have better results on low end if I switched to the E3s.
These (kickers) are in my Titan and they blend quite well but I want them to go alittle lower in the sub territory.
Thoughts?
I had the 8" version of your Kickers, and I had the same problem. If you can fit 8's, get some Sundowns. If not, the ED's will probably be really nice. I've always been interested in trying them
At 40 bones each, who can complain? Personally I'd go with 8" subs over the 6.5's, you cant get but so much out of a 6.5 no matter what, 8" subs have way more output while they can still be used in a very small enclosure. I actually do have a couple of eD's e3.8 8" subs in my truck, and they perform awsome! Heres a video of them...
What cab type is your Titan, and where are your subs placed currently?
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
876
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
FAM4LIFE
SHILOH BOY
FAM4LIFE
Hampton, VA/Waldorf, MD
Josh_101
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
