kicker dvc sub wiring to a 2 channel amp help!!!!
bridged its at 400rms at 4ohms. if i do it bridged id have to wire in series giving 8ohms to the amp so therefore ill only be getting half of power when bridged //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
thanks for responding tho, i still want to know if i can wire the sub to a 2 channel amp but using only 1 of the channels... is it safe?
Wrong section brutha. But yes, you can wire the sub @ 2 ohm to one channel. Depending on what amp it is you might even be able to run it at 2 ohm bridged though I doubt it...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
818
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
jr166
jr166
tulare CA
DoesDad
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
