Kicker KEY180.4 install.
  • 1
AceWoof
UK
Hello, I am looking at installing this Amp with a aftermarket head unit Kenwood dpx-7200dab, my car is a old European Honda Civic 2008 mk8 and I need to use a aftermarket unit because I don't have any Bluetooth on my factory stereo, or even a Aux, just a cd player.
Do I need to splice the wires into this harness which will give me my cars speaker controls or can I just wire the ends with speaker wire and wire directly to the speakers. Also can I just connect my after market RCAs to the amps RCAs. Alot of videos I see on this amp are big bronco and ford truck installs with their already high end radios but I do not have that.
553
AceWoof
AceWoof
UK
AceWoof
    May 12, 2024
Brendon Jenness
    May 11, 2024
