Kicker SS65.2 component set.
  • 2
Upgrayedd
Double dose of the pimpin
652
Ohio
Kicker ss 65.2 component set
Used
$180 shipped and insured CONUS.
Used for a few months as basicly a factory replacement. I sold the car before finishing the system. I believe some mounting hardware is missing but it has been a while. I think the mounts to coax the tweeter are missing along with the retaining clips on the backside of the tweeter. I had them pressfit in. You get what is in the pics. They work great.
If there is an issue i will do another username/date pic
No seperation. No more RS. Only blems of note are some sealant on the back of the mounting flange from them being in the door.
647
Upgrayedd
Upgrayedd
Ohio
Upgrayedd
audiobaun
    May 19, 2024
    May 19, 2024
