SOLD Kicker ZR360
xxxbasshead
Kicker Zr360
does not have the kicker badge or a crossover module included
Details:
* stereo or bridged mono output
* Tri-way capable (Tri-Way crossover required)
* frequency response 10-28,000 Hz
* 90 watts x 2 at 4 ohms
* 360 watts x 1 in bridged mode at 4 ohms (underrated and will run at 2 ohms bridged, not sure about 1 ohm tho)
* 180 watts x 2 at 2 ohms
* MOSFET power supply
* module docking port with 2-way active crossover (80 Hz low-pass, 100 Hz high-pass, 12 dB/octave)
* discrete output transistors
* silent turn-on/off circuitry
* removable endcaps and logo plate
* 18-3/8"W x 3"H x 10-1/16"D
10/10 mech and id say 7/10 cosmetic
175+ship OBO
Will add cash for a good trade.
actual shipping cost thru carrier of buyers choice
756
xxxbasshead
xxxbasshead
lake forst , ca
xxxbasshead
    May 24, 2024
    May 23, 2024
