L port vs. straight port
  • 4
chrisw91
making a box for 2 vvx 12's 4 cubes @ 32HZ and am wanting to make a centered slot port at the bottom of the box. and was wondering if making the port without any corners change anything. basically want the external part to look like this Home Theater Sub Build - Realm of Excursion but dont want to make all of the corners on the inside. or are they needed? sorry if this seems confusing. maybe a box designer can help out!?! might just end up paying for a design... thanks
Not only port noise but resonances also. When you don't put the 45s, or whatever angle you are working with, in the corners, it builds up pressure and that can cause peaks in the response at certain frequencies. Less noticable in substaging, but still beneficial to reduce that.
Nominally, the smaller the port area, the more sensitive it is to reducing port noise and less sensitive to resonance, and vice versa for increasing larger ports. So, a balance can be met for sure, but always better to be safe and utilize them when applicable.
The only major case when they are not as beneficial is for corners inside a compression chamber (main box volume excluding the port volume) where it is compression based, but for tline constants, they are and should be utilized nearly always on any bends/angles.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
858
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
chrisw91
chrisw91
phoenix, az
Moble Enclosurs
