Lithium or AGM
CplCuddles
Certified Meme Warrior
Hey guys,
I am finally getting my electrical system up to par. I am planning on getting a Mechman Elite 320amp and some batteries before my upgrade to a SCV-7500D. Now I know some people say this or that about lithiums so i'd really prefer people who have used or use lithiums experience with them. I'm considering getting something like two Northstar SMSAGM220s or like a Limitless Lithium 45ah.
Not sure which would be better in the long run, not chasing numbers. It's going to be mostly an SPL oriented daily system. I really like the lithium due to the massive weight reduction, i just dunno what I'm giving up there. Thanks m808s
I'd just try the mechman, dedicated ground runs, and a replacement AGM and go from there
You could do 2 banks of caps for less than a lithium and I bet that'd be enough unless you wire at .5
I was always told batts>caps. replacement agm?
Definitely depends on how much VALUE you put on weight and space reduction.
With 320a of alt...even at .5ohm you could get 25ah and be fine.
I will say across the board the results will vary... ex amp seen mb3 @ .5 on stock alt 15ah lith hold 13.8 all day
I see 12.5v with a 25ah
As in the biggest AGM that fits instead of your current battery
There's a lot of misconceptions about caps, so I'm not surprised you've heard that. I could probably remove both my batteries and go with 5-6 banks of caps instead and have better voltage
From a cost standpoint I'd go caps in your circumstance, you'll still get the weight savings
I dont NEED the weight saving, I just liked the benefit of that with the lith, as for cost, I'm very flexible and willing to be patient to get something good. hence the mechman
I’d do dual alts before batts.
The way I'm planning on doing it is like this.
HO Alt
Upgrade front batt to AGM
Add necessary battery to the rear
Get 1 of my Zv5 18s
Get the 2nd and Recone them both with NSv3 or NSv4 Spiders if possible.
Get the amp
Finish system
So basically I should get a 2nd HO prob another 320 before running the 7500D?
I run 600+ amps of alt power with no front batt,6 banks of a caps and a 40ah Juicebox lithium in the rear on 2 sundown scv6ks wired at .35 each....lowest I drop is 13.8 after about 4-5 songs of straight demoing
That doesn't really answer my question, but good for you I guess.
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
  • Locked
I think the guidelines want members to have a picture with your forum username and current date in the picture to avoid scammers. :)
Truth be told, only a few people that put together large (as in my case, 2000-3000) wattage systems are pulling the numbers that they THINK they...
23
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
CplCuddles
CplCuddles
Topeka, KS
Mayhem
    May 31, 2024
    May 24, 2024
