Lithium or AGM
I've ran 1 North Star g34 up front and 3 G31 North Stars in the rear on a ampere tfe 8.0 at .5 alt was a DC320 voltage dropped to 11.8....swapped out the 3 G31s for a Juicebox 40 ah lithium and the lowest I dropped was 12.5....SO with that being said... the lithium held better voltage,shaved of 200+ lbs from the rear and required less wiring to do so....so i say lithium over agm
Keep the 320
Biggest AGM in the front
Get as many banks of caps as you can afford for the rear
I use a mix between AGM and caps for my system. 100% daily use. Best investment I ever made for my electrical was getting caps.
Night and day different in voltage stability and recovery.
Lithium is too expensive imo. Wouldn't say it's not worth it but you can get 5 banks of caps for the price of one limitless 45ah...
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
  • Locked
I think the guidelines want members to have a picture with your forum username and current date in the picture to avoid scammers. :)
Truth be told, only a few people that put together large (as in my case, 2000-3000) wattage systems are pulling the numbers that they THINK they...
23
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
CplCuddles
Certified Meme Warrior
CplCuddles
Topeka, KS
Mayhem
    May 18, 2024
    May 18, 2024
