[LNIB] Kicker Warhorse 10,000 Watts RMS
ahole-ic
Banned
3,034
Ivory Tower
Kicker Warhorse 10,000 watt amplifier
This amplifier was recently traded to me from a respected forum member "Wone". I have unboxed it only to take pictures of it and to power it up on my bench to make sure that it does in fact power on. I see no scratches or any markings. It looks mint.
Specs taken from sonicelectronix:
Warhorse Series Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 5,000 watts x 1 chan.
2 ohms: 10,000 watts x 1 chan.
Max power output: 20,000 watts x 1 chan.
Signal Modulated power supply allows for ultra-high-efficiency
Wired remote bass level control included
Unique power supply allows for amplifier to output 10,000 watts with 90% efficiency
8 green LED indicators display the status of the amplifiers protective circuitry and assists in troubleshooting
Variable Bass Boost (0 to +18 dB bass boost at 40 Hz)
Preamp RCA outputs to daisy chain multiple amps
Separate voice coil wiring terminals allows for user to hook up each subwoofer voice coil to dedicated terminal
High-density split-dome convection heat sink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Input sensitivity:
Low level: 170mV-5V
Variable low-pass filter (50-200 Hz, 24 dB/octave)
High Pass Subsonic filter (20-60 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-200 Hz
Dimensions: 35"L x 17-3/4"W x 3-3/4"H
Minimum Power Requirements: Eight 12-volt Batteries, and two 200-Ampere Alternators. For more information regarding the Warhorse Power Requirements, please read the User Manual
Triple 1/0-gauge power and ground wiring is required for installation.
$1300.00 Shipped.
Shipping is included in the price
Ok cool thanks for that info. I could use a pair of these on my pair of dual 4 ohm SA15s!! 1 warhorse per sub!! Then my head explodes:pissed://content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
Make me an offer via pm.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
756
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
ahole-ic
Banned
ahole-ic
Ivory Tower
TurboRedneck
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
