Look what I found yesterday!
Joseph7195
Walkin Tall
I have been dreading opening this rear axle up, but I finally decided to tackle it and I am glad I did! This is the outer pinion bearing race. Definitely has some problems!
I still have to measure backlashing and some other stuff, but I don't have much left to do. If I was to let a mechanic do this work it would have cost over $700.00 just for the labor! I am doing it all for less than $300.00. This is why car audio and vehicle maintenance comes so naturally to me, it's all about learning!
Looks like pitting from rust/corrosion. What kind of rear end is it? Ive tackled a few of them. I have about 100$ in specific tools needed to do it, but better than the 600$ for install at a shop. What are you using for marking compound? Lipstick works good, its hard to find actual marking compound it seems unless you buy online.
It's a Chrysler Corporate 9.25". That's why it costs so much. I have the carrier bearing spanner tool already and the back lash caliper. I was able to find a total rebuild kit online for $129.00 on Jegs.com. It's has to be the most finicky rear end I have ever rebuilt. You got any good tips for removing the bearings from the third member and pinion? I am trying to save the 30 bucks to have a shop press them off and new ones on. And you got any other tips UniBrad?
I cleaned everything and I don't believe I have any internal problems
I took these pics just in case someone else saw something fishy, but after a couple of times thoroughly looking it over, I believe I just caught it early and bearings were the only thing needing to be replaced!
Is the truck lifted or have non stock tires
Nope, just regular factory heights and tire sizes. I am probably not gonna upgrade those either. If it was 4 wheel drive, i would have upgraded in a heartbeat!
Want finicky? Try a GM corporate 10 bolt.
No Thank you, No Thank You, I definitely don't want anything that's more finicky! I honestly don't want to imagine something harder to rebuild! lol
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Dammned good amps. I ran that series for years. I just sold my last GTQ400 last year. I still have a GTS600 left. that series will run up to 16v...
When you random through your music library, you know you got your gear dialed in nicely.
18
Joseph7195
Walkin Tall
Joseph7195
Saltillo, Mississippi, United States
dumple
    May 18, 2024
    May 18, 2024
