Loudest Off of 500 Watts
Fastball
FL
Currently I have two memphis pr 10's in a sealed box and I want to go louder, but with the same 500 watt amp I am using. It would be going in the back of a Nissan Frontier so air space or size of sub will not matter to much.
Thanks for the help.
Yeah that was one thing I was thinking about, but wasn't really sure how much of a difference that makes. I'm guessing it would be pretty noticeable then?
what part of florida are you in?
Well i guess i am definitely going to port them since everyone is suggesting it. On the spec sheet it says 1 c.f. at 40 hz. Does that sound good or does anyone have any better suggestions?
I live right by Cocoa Beach, just on the other side of town from you. lol
that sounds awful
Port them. I was going to suggest Memphis PRs when I saw the title
x2, i think the only way you would get louder is more cone area.. with exceptions, but i wouldnt expect much of a change.
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
375
352
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Fastball
Fastball
FL
Etac
    May 31, 2024
    May 24, 2024
