Maybe the stupidest question today
  • 6
Well if you are using separate amps your rcas will run to the amps. The speaker wires from the headunit won't be used if you are using separate amps to power your speakers.
If you are just going to use the headunits built in amp then you won't use the RCAs and will use the speaker wires.
Thank you for the intelligent answers instead of an unhelpful comment. Glad there are people here that actually will help those that don't have the experience. I can now hook it up properly.
28039
I know I am a little late to the party. I have ran both RCA outputs to amplifiers AND the high level speaker outputs from the same head unit, at the same time. (Sony, Kenwood and 1 Pioneer).
Some head units allow you to turn off the internal amp if using RCA's but you can run both at the same time if that was your original question.
Don't use the speaker wires and the RCA's on the same speaker though.
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
775
Yeah... check this link out. It shows the power handling of that tweeter. I'd just match the power no matter if you use the crossovers or not...
7
939
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
314
beb
beb
Lake Havasu AZ
ThxOne
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
