mb dsc4125 (crossover)
  • 3
so this is right thats weird
I dont see whats wrong with it. The 4125 is for speakers. 10Hz to 1.2Khz is more than enough. Your subs should pick up around 60Hz and down. From 60Hz and up to 1.2Khz. I guess its an issue if you want to run active and cross your speakers over higher, but who goes active at the amp crossovers anyways?
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
451
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
9
jdmferio13
feayfm
jdmferio13
Central,PA
whitedragon551
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
