MB Quart DSC4125 input voltage
  • 3
badstang123
Hey guys. I was wondering if the MB Quart DSC4125 can take a 8 volt input voltage? I did some searching on the forums but didn't come up with anything. I did find that the "Variable Input Level Control" is 0.2 - 6.0v in the MB Quart manual. Is that the number I'm looking for? And if it is, if it can take 6 volts is 8 really going to put me over the top or can the amp probably handle that safely? Thank for the input.
I'm using a Pre-Amp EQ with a 8v line driver. I'd imagine at times it will put out the entire 8 volts. This being said, Kylebechtold is probably right, checking with MB is the only way to guarantee the safety of the amp if no one else has actually tried it.
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
3K
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
6
534
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
825
badstang123
badstang123
Los Angeles, CA
badstang123
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
