mdf or birch
Mdf works good and so does birch. The difference is birch is a lighter hardwood. So that 3/4 birch will work as good as 1" mdf with a fraction of the weight.Only thing is make sure its a solid birch, not a birch covered plywood
Birch, lighter, stronger, less mess. around here theres about $5-10 difference between .75 mdf and .75 birch. birch 40 /sheet
Then that is birch laminated plywood. Outside layer is birch, inside isn't.
True baltic birch will be around $100 for a 5x5 sheet of 1" thick.
Birch isnt THAT much more expensive than MDF. As a percentage it is, but its going to be like $10-$15 a sheet more usually.
Birch is lighter and stronger, but I dont like the way it cuts, and it splinters when you cut it. Hard to get a nice looking edge when its all splintered and shooting little chunks of wood into your face.
MDF is heavier and not as strong, but cuts like butter and is much easier to router. ***** it makes so much dust though.
Really depends on the application.
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
17 layers and it's worth it. Get the Russian stuff if you can. $206 per sheet in Vegas these days.
25
5K
rosszilla23
rosszilla23
chi-town
SpeedEuphoria
    May 18, 2024
    May 16, 2024
